misfit138
a whole new type of aids
met a nice girl. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif^^^oh yeah why is that?
Okay, well that helps. I was trying to find out whether there would be any advantages of running my subs at 2 ohm vs. 1 ohm. I need to figure out whether to buy (2) 4 ohm or (2) 2 ohm subs since the 2 ohm subs won't wire down to 1 ohm. I realise that it would be cheaper as far as an amp to run them at 1 ohm. Is it worth the extra money for a better amp to power them at 2 ohm or should I save money and run them at 1 ohm? Thanks, X.okay it depends on what your goal of your system is. if you just want a little bump in your trunk then just peice it together...meaning you can normally find a brand new amp that does its max rated power at 1ohm so just buy that and make sure your sub and or subs wire down to 1ohm...it doesnt make a real difference 1 or 2 ohm and honestly i dont even get what youre trying to ask so this answer is even hard for me to type //content.invisioncic.com/y282845/emoticons/sick.gif.b1847c8dabbfeeddbcf1a78052249e10.gif
I'm thinking I could save money running them at 1 ohm since amps generally have more power at 1 ohm. Does that sound right?okay it wont make any difference running your amps at 1 or 2 ohm...reason is some amps are made to do max power at different ohms to meet the needs of different applications.
there isnt any real difference...ive ran at .7ohms, 1ohm, 1.67, 4 and now going to 2ohm...no difference anywhere just picking different things...like this time around my subs will wire down to 2ohms and be run off a amp that does max power at 2ohms...and the reason im doing this is the amp is cheaper
