Should I run my subwoofers at 2 ohm or 1 ohm?
okay it depends on what your goal of your system is. if you just want a little bump in your trunk then just peice it together...meaning you can normally find a brand new amp that does its max rated power at 1ohm so just buy that and make sure your sub and or subs wire down to 1ohm...it doesnt make a real difference 1 or 2 ohm and honestly i dont even get what youre trying to ask so this answer is even hard for me to type //content.invisioncic.com/y282845/emoticons/sick.gif.b1847c8dabbfeeddbcf1a78052249e10.gif
Okay, well that helps. I was trying to find out whether there would be any advantages of running my subs at 2 ohm vs. 1 ohm. I need to figure out whether to buy (2) 4 ohm or (2) 2 ohm subs since the 2 ohm subs won't wire down to 1 ohm. I realise that it would be cheaper as far as an amp to run them at 1 ohm. Is it worth the extra money for a better amp to power them at 2 ohm or should I save money and run them at 1 ohm? Thanks, X.
I think you want to know what the pros/cons of 1 ohm or 2 ohm would be on your amp and elec system.
Are you wanting to know whether to run a mono amp or a 2/4 channel amp on your subs? The mono amp will pull less current, more efficient and less heat @ 1 ohm. Not many 2/4 channel amps stable @ 2 ohm bridged.
Some mono amps have the same power rating @ (1 through 4 ohms). So I guess this is a current question @ 1 or 2 ohms?
Hope this helps.
I'm wanting to know whether it would be better to run subs at 1 ohm or 2 ohm and why. That's it. I explained this earlier.
"Okay, well that helps. I was trying to find out whether there would be any advantages of running my subs at 2 ohm vs. 1 ohm. I need to figure out whether to buy (2) 4 ohm or (2) 2 ohm subs since the 2 ohm subs won't wire down to 1 ohm. I realise that it would be cheaper as far as an amp to run them at 1 ohm. Is it worth the extra money for a better amp to power them at 2 ohm or should I save money and run them at 1 ohm? Thanks, X."
okay it wont make any difference running your amps at 1 or 2 ohm...reason is some amps are made to do max power at different ohms to meet the needs of different applications.
there isnt any real difference...ive ran at .7ohms, 1ohm, 1.67, 4 and now going to 2ohm...no difference anywhere just picking different things...like this time around my subs will wire down to 2ohms and be run off a amp that does max power at 2ohms...and the reason im doing this is the amp is cheaper
I'm thinking I could save money running them at 1 ohm since amps generally have more power at 1 ohm. Does that sound right?
Would I be able to hear a sound difference between a 1 ohm subwoofer setup vs. a 2 ohm setup? I heard you receive more sound quality at higher ohms?
Thanks.
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
The CT's are nice, That Sundown is a a frik'n beast!
786
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
670
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
776
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
Xanthous
Xanthous
St. Louis, Mo
Xanthous
    May 23, 2024
SPLBassJunkie
    May 21, 2024
