Should i dial it back?
Should i dial it back???
  • run 3 8's with ample airspace
    Votes: 10 76.9%
  • run 4 8's with minimum airspace
    Votes: 3 23.1%
  • Total voters
    13
You have 13.5 height and still be under the cover.. I dont know where your getting the 9.5 from. Unless you want to upfire but that would be dumb firing into the cover
More height limits my depth tho. Because of the way The hatch slopes down.
I'm taking the cover off either way
On a kicker 1500 at 2 ohms?? Lol id have to see that.
i know you have a thing for kicker.................but
they tried comparing a brutus 1600 to a xx zeus and here is what the hifonics rep said
The Brutus BXi1600 series is our every day, basic retail amplifier.It provides 1600 watts @ 1-Ohm / 14.4 volts.
It's a good bang for the buck amp.
The XX Zeus is one of our many competition level amplifiers.
1600+ watts @ 1-Ohm / 13.2 volts.
These amps are built to handle higher operating voltage, run under lower impedances and stand up to the volatile operating conditions of serious competition.
The XX series have these advantages over the Brutus line:
1. 25% more and larger output devices
2. Larger / more regulated power supply
3. Heavier hand wound toroids.
4. 30% increase in heat sink mass per mm
5. Balanced Line Input
6. Top Mount controls
7. Clipping indicator light
8. Strappable for master/slave operation.
9. Larger power, ground and speaker terminals
10. Heavier 2 sided pcb
11. Heavier copper component traces.
Why So Cereal?
Invisible Cereal
Why So Cereal?
Drowning in milk
Why So Cereal?
michigan born
    May 14, 2026
michigan born
    May 14, 2026
