I'm really glad I posted this thread. I wasn't really aware of the power requirements... I was under the impression that I would need 0ga wire if I was pushing OVER 5k watts. Just a silly misconception I had. I'm glad it's been cleared up.
So to get this straight:
Run 0ga wire to distribution block from battery. Run 0ga wire to AQ2200 and MRP-F240 from distribution block. Run 0ga grounds from each amp to an independent grounding location, which I'm going to scratch off with a brush to get down to the metal.
Then for Big 3:
1) alternator positive to battery positive, 2) battery negative to chassis, and 3) engine ground to chassis.
I hear its optional, but recommended, to also ground the alternator to the chassis as well. Is that done via a terminal, or just a bolt on the alternator?
I need to buy a battery distribution block that lets me hook up multiple 0ga wires. Have any good ones I can order?
