SHOULD 4 channel become 2 ???
ROOKIE QUESTION..I am buying an amp for my front component speakers....CAN I..better yet ....SHOULD I........USE A 4 CHANNEL AMP AND BRIDGE IT TO 2 CHANNELS TO POWER MY "COMPONENT" SPEAKERS.....do people do this...why...why not etc...The main reason I ask this question is because I have access to some good quality 4 channels???
Thanks
Is that what you mean by Watching the ohm load. Most components can only be run at 4 ohms...for example the Fosgate 400A4 is 100watts by 4 channels or bridged 200w to 2 channels at 4ohm..I will have 200w running to each component..Safely and wisely..????or not???
P.S. Basically I have access to older but "NEW" Fosgate 400A4,600A4 amps etc...Is it true the older fosgate amps (pre-2001) are better than thier new models. They sell "used" for more on EBAY than the Brand new Fosgate stuff..I realize this may cause a debate..but I have heard this opinion alot???
Is that what you mean by Watching the ohm load. Most components can only be run at 4 ohms...for example the Fosgate 400A4 is 100watts by 4 channels or bridged 200w to 2 channels at 4ohm..I will have 200w running to each component..Safely and wisely..????or not???P.S. Basically I have access to older but "NEW" Fosgate 400A4,600A4 amps etc...Is it true the older fosgate amps (pre-2001) are better than thier new models. They sell "used" for more on EBAY than the Brand new Fosgate stuff..I realize this may cause a debate..but I have heard this opinion alot???
IIRC- the old 400a4's will be fine at 4 ohms (2 channel mode)
2 ohms would be a stretch unless it is the power series.
You should still be ok with your current configuration plans.....
IMO- Older Fosgate Amps are a lot better in virtually all ways.
I haven't seen much that can stand up to my old Power 50.2
take it easy,
-zane
Depression
ISSUES
Depression
Los Angeles?PEBBLE BEACH NOW
zane
michigan born
    May 14, 2026
michigan born
    May 14, 2026
