Hey guys, Needing some help as a newbe at this, years ago I've setup few systems, but that's been years ago and technology has changed a lot! This set up is going to be in a small offroad 4x4 2 seater tubed style car, so everything I'm using will be marine. The main thing I need help with, is what type and size of amp to use, I want to use something fairly cheap, as being exposed to the outside elements can take its toll on things! Hate to spend $800+ on an amp that I mess up from water! So i'll make this short and do my best here.
I have limited info on the front speakers and subs as they are a factory brand in molded enclosure's
front speakers-"two" 6" 50w
Sub-"one" 10" 500 watt (250w RMS)
Rear- "two" 6 x 9 Peak: 550 watts each, RMS: 275 watts each, 2-way Wake tower Speaker
As for a head unit, I do not have much room at all, and really do not need a cd player, This is what I had in mind, then just use an Ipod plugged into it
JENSEN AM/FM/USB Compact Waterproof Stereo
So what kind of marine amp should I run? How many watts? Channels?
The few amps I was looking at are Boss, Clarion, or Audiopipe?
This is the audiopipe I had in mind?
APMR-4080MIN - 1200 Watt 4-Channel MOSFET Mini Marine Amplifier
So, What does this look like? Am I anywhere close to being on the right track what so ever? Please feel free to tell me anything you see here and don't like? Or do like, I'm up for any suggestions!! Like I said the only thing I'm really stuck to are the fronts and sub. I can change anything else! Any help will be great!! Thanks
