Setting up gain question JL Audio
jcof88
hi its me again just had another question i have alot of clipping from my JL audio component set and my JL audio amp goes into protect mode, I have taken it to wet audio and they didnt seem to fix it so i am trying to do this my self, so i know i need to use a multimeter with ac voltage i just had a few questions first, I have a JL Aduio JX360/4: 4 Ch. Class A/B Full-Range Amplifier
says power ratting is :
RMS) Power @ 14.4 V
@ 4 Ω 70 W RMS x 4
@ 2 Ω 90 W RMS x 4
Bridged @ 4Ω 180 W RMS x 2
and
RMS) Power @ 12.5 V
@ 4 Ω 55 W RMS x 4
@ 2 Ω 80 W RMS x 4
Bridged @ 4Ω 160 W RMS x 2
the power volts is your car battery right, so next i have my JL audio component set and 6x9 to this amp the front are hooked to channel 1&2 and 6x9 to 3&4,
Jl audio C2-650 2-Way Component Speaker System
Continuous Power Handling (RMS) 60 W
Peak Music Power 225 W
Recommended RMS Amplifier Power (per Ch.) 15 - 100 W
System Efficiency 91.0 dB @ 1 W / 1 m
System Nominal Impedance 4 Ω
and Jl audio TR690-TXi: 6 x 9-inch 3-Way Coaxial Speaker System
Recommended RMS Amplifier Power (per Ch.) 10 - 100 W
System Efficiency 90.5 dB @ 1 W / 1 m
now both of them says System Nominal Impedance 4 Ω so does that mean i am only getting @ 4 Ω 55 W RMS x 4 that dont seem like alot, ?
one last thing is that is the case in the Jl Audio Amplifier Target Output Voltages says for
JX Amplifiers Voltage Chart
4Ω(or higher) 16.7 V
3Ω 15.5
2Ω 13.4
So do i want the 16.7 knowing the speakers are 4Ω hooked up to channel 1&2
Thanks alot i know its alot but trying to do this my self sense i cant get an audio shop to do it right thanks again
yep, play a test tone (50Hz) and measure AC Voltage on the amp output with the speakers disconnected and the crossovers turned off. use a HU volume that you never exceed.
then turn off the system. set the crossovers, and reconnect the speakers.
50W is plenty. a head unit is good for about 5W.
jcof88
jcof88
Columbus, Oh
keep_hope_alive
