Setting the Gain?
You unhook the sub and hook straight to the amps speaker output set it to the correct ac voltage using a good test tone with all x-overs off and the eq set flat and then hook the sub back up.
You measure voltage out of the amp, not current.
Thanks for the correction. I was thinking it correctly. Just lost translation from my brain to my fingers.
Thanks for the link. I've seen it before. Guess I didn't read it verry well the first time.
nother stupid question, if I may: I read that the other channels may be disconnected ( channels not being tested ). Is this not harmful to the equipment to opperate without a load?
SparkyFord
SparkyFord
Cabot, AR.
SparkyFord
Doxquzme
    Jun 20, 2026
Doxquzme
    Jun 20, 2026
