Setting help
eus090474
I have tried reading the manual and doing some research but I am not smart enough to figure it out. Can someone please break it down potato head style for me please? I have a Polk pa600.1 mono amp with a kicker 15cvr. The sub is wired in series and bridged on the amp. Can someone please tell me how much power and how many ohms it is at? I know it is a dumb question but I just can't seem to get it right.
Sorry, dvc4
If you wired the voicecoios in series then you have an 8 ohm load at the amp. You want to wire it in parallel to give a 2 ohm load. This is if you have a single dvc4 which is what I thought you said right? And just make sure your sub can handle the wattage your amp puts out at 2 ohms
How would that chang the watts? It is a 600 watt amp, is it possible of more than 600? Again, sorry for the dumb questions, I'm still learning.
check out the specs of your amp. the amp will put out different power at different ohm loads. the norm is usually rated at 2 ohms. so your amp probably does 600 watts at 2 ohms, 300 at 4 ohms...etc. you have to see what your amp is rated to do and match the the power rating of the amp at a certain ohm load to your subs power handling. in your case you can only wire your sub to be 2 or 8 ohms so you want to have it wired in parallel(2 ohms) to pull the most power from your amp
eus090474
eus090474
Chicago, IL
eus090474
