xluben
if you have DVC 4 ohms subs each should have the coils wired to 2 ohms, and then one sub to each ouput on the amp will have the amp seeing 1 ohmOne other thing that I am unsure about is the way my speaker wire is going from the box to the amp. I am currently using a pre-fab box that has 2 terminal cups. The voice coils are wired to 1 ohm. The amp has (2) positives and (2) negatives; they parallel internally. I have each sub positive and negative going to the individual positives and negatives on the amp. Is this the proper way to wire to run at 1 ohm?
sounds like you have it right.
if you have the subs wired up with one to each output, you need to measure the voltage across the output bridged! hook the DMM up to the + on one output and - on the other and see what it reads.
looks good. try hooking up the DMM as stated above.The settings of the amp are:subsonic filter: on
LPF: 90Hz
The test tone is 0dB @ 50Hz. I got all of my test tones from http://www.realmofexcursion.com.
