Setting Freq. help with active setup
Audio control has a nice one. LCD display and a dash mount control.
---------- Post added at 09:30 PM ---------- Previous post was at 09:29 PM ----------
Your tweeter CO point is going to depend most on where in the car its located. The higher up it is away from the mid the lower you want it to play.
not always necessarily.
kind of not looking to dish out to much more money on another amp. So how exactly do i install crossovers i never messed with them
kind of like an amp, power, remote, ground...input RCAs to the crossover out to the corresponding amp channels. Its pretty self explanatory.
If you want to bring the vocals up front it is.
In a 2 way front stage, I kinda-sorta agree, although I'd base it more off how high your mids can play before beaming has too much an effect. But, one of the main reasons to do a 3 way front is to have the vocal range covered by one driver. Setting your tweeter point too low defeats that purpose. Unless you're just after extra midbass, I dont see the point in doing 3 way with a low playing tweeter. Sure, someone can make it work, but chances are a 2 way would have sufficed with some work in that case. The way I like to look at it is, in a 3 way front, tweeters should be used to "anchor the stage". The speakers will already be out in front of you and with some good processing, the vocals will be out in front. The tweeters shouldn't have to do much but brighten the vocals, help stage height and help define/stabilize the imaging.
I can say this. I have the tweets on the sail panel. The amp is in a rack where the back seat used to be. I had the CO set around 3K at first, It sounded low. I reached back and moved the CO a few clicks down and the stage went up quick. That was my sweet spot.
Hey, if it works, it works man. I'm at 4khz between mids and tweets and the vocalist is about halfway between the dash and rearview mirror, heightwise. No one can tell anyone else what will sound good to them all we can do is offer starting points and personal experiences. Especially since we all have different equipment, installs, and ,most importantly, different ears! I just wanna hear that beast of yours.
Hey, if it works, it works man. No one can tell anyone else what will sound good to them all we can do is offer starting points and personal experiences. Especially since we all have different equipment, installs, and ,most importantly, different ears! I just wanna hear that beast.
Thats very true. I had so many people say so many different points. Equipment, ears, and install all play a role.. Im pretty sure Im ready to hear it also. Im ready to get the sub box in already.
i do not have them deadened yet but i will be getting them sealed up for sure. thats what i am looking into. i may get the audio technix or maybe try that new stuff from sonic electronics that nvx
KenC210
KenC210
San Antonio, TX
maylar
