setting amp settings
Rockguy475
should i be using my high and low pass filters on my amp? can anyone help with setting my amp correctly? i have the jlHD900/5 powering a W6 and 4 JLc2 speakers (fronts run at 60 rms and the backs run at 70) im not sure if im supposed to be using the high and low pass filters. this is my first install
One way or another, you need to low pass the sub and hipass the mids. The JVC probably has LPF automatically when you enable the sub outs, so set it at 85 ish and don't use the amp LPF. The mids need HPF on the amp, somewhere around 80 hz is good.
ok ill give that a try... anything i need to do with my highs?
Rockguy475
Rockguy475
houston
maylar
