Will this amp kit be good for my setup
KnuKonceptz says the 4awg CCA wire is good for up to 100A of current. The kolossus 4awg is good up to 150amps. It's up to you to decide. Both are good. However, even if you don't run over 100A, Kolossus should be better IMO.
A bigger fuse is not your best bet. It depends on your amp and what it pulls...(ie have a 100 amp fuse with a amp that pulls 60amps will not protect your amp the way it should) that kit is fine for what you are doing
Jberger93
Jberger93
Pittsburgh, pa
PocketRocket
