setting amp settings other than the gain?s
99grandprixGT
now got an 04 grand prix
alright so i want to install me amp today after class. my wiring kit should be here at that time. but i need to know what to set my subsonic and the low pass at. and bass eq? i think this is bass boost? so ill have that at 0. im going to set the gain with a DMM so i know how to do that. just need to know about subsonic and low pass. my set up is two type R 12s in 4.0 cubes tuned to 33hz if that matters. thanks for the help.
the subsonic should only be used in ported boxes, and if its a variable filter, set it 2-5hz below your tuning on your box. if its a sealed box, turn the subsonic off.
the low pass is a crossover basically, it lets you select the frequenecies that you want heard, and the rest get ''rolled off''
i set mine at halfway around 100hz, its the highest note it can pick up, the rest get rolled off.
all right thanks man. so ill set the sub sonic at around 27. and the low pass at 100.ill see how it sounds.
box tuned to 33?
I'd say drop subsonic @ 28-30.
low pass should be @ 80-100
bass boost? fuxors! Don't touch that shiz
this concludes my announcement lol
box tuned to 33?
ya man i know not to use bass boost. lol. but thanks for looking out. ya ill try out the subsonics at 28. thanks guys.
99grandprixGT
99grandprixGT
home
GAM3OVR
