selenium tweeters and bass blockers
that_one_guy
i'm looking to install two selenium st200 tweeters.
Selenium Two St 200 140W Super Tweeters Speakers 1792719021664 | eBay
would these bass blockers be what i would need to go in line with the tweeters?
Amazon.com: Stinger SGJ96 0-5.6 KHz 4-Ohm Bass Blockers Blocks for Tweeters: Car Electronics
those a good pairing?
also, the tweeters are 8 ohm.
i assume tweeters work the same way as subs, i can wire them in parallel to make a 4 ohm load, and bridge my amp and run them together off the same output (i also assume i would lose the left and right (stereo) and the tweeters would be mono, so they both play the same sound...
right?
any other advise\info\tips on tweeters, i've never put tweeters in.
thanks
you want to get 8 ohm bass blockers.
and buy them from Parts Express.
Selenium ST200 Super Tweeter | 264-348
get one of these for each.
5 kHz High Pass 8 Ohm Crossover | 266-474
these are 12dB/oct slope which is better than a typical "bass blocker" which is a 6dB/oct slope.
these are plenty efficient. run them in stereo and maintain a stereo image.
you could wire them in parallel and bridge the amp but there is no good reason to do so and you're just making things worse. your balance and fader should always work properly. if not, you're doing it wrong and just listening to noise.
the reason bass blockers or passive crossovers need to be made to the speaker's impedance is because that affects the crossover point.
for a simple 6dB/oct crossover:
a 4 ohm crossover would behave 2x as high if wired to a 8 ohm tweeter (crossover frequency is doubled when speaker impedance is doubled)
the real danger comes when using an 8 ohm crossover on a 4 ohm tweeter because the crossover frequency is halved.
with higher-order crossovers the effect is worse because values move in opposite directions
i got the massive nx2 today
(the st200s and 5khz 8ohm crossover as well)
should i set the amp to high pass filter, or all pass and let the crossovers do the work?
does it matter?
set amp to FULL since you have external xovers as you don't need/want the amps xover circuit working. And you do NOT need anywhere near 60watts each for those tweeters...
so, which is it?
both methods work fine. you don't need to use the crossovers on the amp but without them, the amp will produce full range and try to amplify low frequencies. The passive crossovers just provide a higher impedance to frequencies below the crossover point, but amplifier power is still wasted. the crossover circuit doesn't consume power but it will affect phase on the output.
I did an adire koda 8 for now but I'm considering swapping it to a Dayton ho 10. More cone area for more midbass. But I might not need to. I might...
16
You can Email or Call GP Audio and they can make some adjustments to make the enclosure shorter and either deeper or longer on the Glue and screw...
114
8K
I had this same issue with my Sony. When I first got it I had speakers hooked up to the head unit without amplifiers and it worked fine. Once I...
that_one_guy
that_one_guy
amerika
keep_hope_alive
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
