SAZ3000 cuts out on low notes
lol you know my battery game is strong jimbo
---------- Post added at 11:18 AM ---------- Previous post was at 11:18 AM ----------
still want 2 more
I'll bet you both are discharging your batteries super fast on that low note check voltage at the amp when that note hits
you know my setup. i have a voltmeter hooked up to the 0gauge right at the amps input. its gone into protect at 13.7 before also at 12.9 and 13.3 it varies and i know its correct i checked also with a multimeter
But have you watched the voltage and seen how far it went down when the amp went into protect That's what you need to know. Even if it's just a split second if your not watching when it does go into protect you might still see a 13.8 I had a system do the same a few years back as soon as I turned it up and it hit this one certain bass note the amp would protect. My voltage always looked good. But I was told to watch the voltage at the amp when playing the song. And sure enough when it played that heavy bass note. I dropped from 14.4 to 8 volts quickly. The amp protected. And the voltage went back to 14.4 right after
don't they make a dip volt meter that will do a hold at the lowest point? maybe I'm making things up in my head but I could swear I've heard of a dvm before.
*edit* I may be a retard on this one, can't find anything... but if there are meters that will hold the low point as opposed to the high point that could help.
a few times it hasnt even been on a deep bass not its probably 45hz. and i have watched it closely. ill troubleshoot with josh monday and call you jim
---------- Post added at 03:25 PM ---------- Previous post was at 03:25 PM ----------
thats that ish i do need
Yea let me know. It's a nice amp I never had an issue never ever protected once
302yota
302yota
rockingham, NC
mylows10
Doxquzme
    May 14, 2026
ThxOne
    May 13, 2026
