Rockford Fosgate power hx2 12" box specs
  • 2
Ferra3904
I just picked up a Rockford Fosgate power hx2 12 for $30. It works but the spider sags like it's not even there. I'm going to recone and upgrade so I need to know what's the best volume and tune for this sub running at about 2,000 watt rms in a 98 honda civic. Manual says 2.5cu.ft at 40 hz so just seeing if anyone has a experience with these and a better setup. Does it do better on 4th order, 6th order or just regular old ported. Thanks for the help
I'm sending it into fix my speaker to get them to build it. I'm wanting a daily so not going to crazy so need a volume and I'll just experiment with aero port to find the tune I want
David (fixmyspeaker) should be able to give you a recommendation; otherwise I would shoot for around 2 cubes. I ran mine at 1.8 cubes tuned to 33 off 1000W and that satisfied my needs.
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
Ferra3904
Ferra3904
United States
Ferra3904
    May 24, 2024
