RE's new sub
if you say so...
i never said they copied mtx, but just look at them. the surroud is identical, the basket has the same shape, and the magnet is reletivly the same look. now i know looks have nothing to do with performance for the most part, but they look similar.
As was said, they dont use the same parts. With what RE is doing with this new sub, specifically the excursion capabilities, you dont simply pull existing off the shelf parts and assemble them into this new sub.
The frame is custom by RE (I remember them saying the frame redesign held the project back a while ago). The closest frame Ive seen to this one is the GZ Plutonium, now that frame was similar. The magnet, well the RE sub uses much larger diameter magnets than the 9500 (approx 10" in diameter), the 9500 being triple stacked and I believe the new RE is double stacked (but again bigger magnets). The new RE sub also has new/custom top and back plates, so I dont understand where you see the similarities to the 9500 motor structure.
The surround is the only closely similar feature I see, and that tall surround design is hardly unique to the 9500. *shrug*
if you say so...
Right..you realize how many different materials go into to tooling a surround? Not only is it not the same, it does not preform the same. It's designed to actually use the surround that it has been given...instead of just being there along for the ride....
I was just kidding Nick. But I was right, Kent proved it for me //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I wonder how many new threads there will be about it before it gets released?
Yes the mounting depth is extreme, but what can you expect when you start pushing those kinds of excursion numbers. But I agree, alot of people dont realize you aren't gonna plop a couple of these in the back of your civic.
LOL you watch me do it. Ill put 2 of them bad boys in there, 15's. If a guy can fit two memphis audio 15" LVS's in a civic then this new sub will be no problem //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif What is the mounting depth anyway dont look anything close to a memphis LVS which is 11.75 for a 15. i have no idea what the mounting depth is on my sub but i no its 10" tall and HEAVY.
Not to sound rude but im pretty sure the mounting depth will be more than 11.75". Look how much larger it is than a 15" XXX which has a pretty large mounting depthe. I do not knw the specific mounting depth of an 15" XXX but i do believe it is somewhere around 10" give or take.
they are both 12s....
Well my TAHOE is READY!!!
Naw its coo man i wasnt to sure on the exact numbers either but looks like i may of been wrong but you better believe im gonna try and see if it will fit in my car and if i can get a good deal on one ITS ON LOL even if it means goodbye to my trunk
I just put a tape on my XXX 15's, their mounting depth is just over 9 inches. Judging from the pics, the new sub is a good 3 to 4 inches deeper than that. Its easily as deep as the LVS.
I just called RE (to order my XXX mids) and talked to Mark. He said he has no idea where the guy (ngsm) got the info that the new sub would be called XXX and the current XXX would be called something else. He said they have no plans to do that and that notion made no sense to him either. *shrug*
edit: He also said the tooling and parts are all done on the new sub, but the engineers are still tweaking the design a bit because they feel they can improve it. He confirmed the new ship date is expected to be June or July.
BTW I said a 'pair' of these earlier. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif I bet you can fit one (if the depth allows). Good luck.
HAHAHAHAHAHAH, check my original statement in this thread now...see what was asked of me!
They aren't gonna straight up tell you...nice try tho...
NG
NG
You editted your original post to remove the comment, so? I still wanted to follow up, and according to Mark, you were wrong.
Not sure what you think Im 'trying' to do. *shrug*
SoLowitHrz21
SoLowitHrz21
Daytona Beach FL
chinny
