Recomend a small footprint powerful amp
i have a Arc Audio ks 1000.1 with 2 12 IDQv.3 and i love it, paid $500 at wooferetc.
Dude do u work for a company and try to rep their products/website here?? Every thread that you post in looks exactly like this.
Definitely looks a little bit suspect to me.
I call BS on these Sound Digital amps... //content.invisioncic.com/y282845/emoticons/plthumbsdown.gif.d7966af824c93c6021d1aae1778b1c19.gif
The 1800w model has only one 80 amp fuse to make their claimed 1800 watts at their claimed 12.6 voltage..
This model would need 140+ amps of fusing if it was 100% efficient..
1800w / 12.6v = 142.85 amps to make power..
You would have to run at 100% efficiency to make that 1800 watts @ 12.6 volts with 142.85 amps to boot!//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif I always thought SD was pulling numbers out of their ass, unless they figured out a way to generate power and violate Ohm's Law.
The 2009 line doesnt use fuses anymore.
So now, what? We produce amps that actually make the power?
Those fuses ar MAXI which are retarded, they hold 3X its rated current for small amounts of time, but if you play a test tone for more than 4 or 5 seconds they would open.
And BTW, if you buy a SD amp and you measure less power than we rate the amp we give your money back.
i beleave Murilo clamped his SD3000 in his truck and it makes just over 3000watts at almost 4ohms. yeah that sounds like BS to me!
//content.invisioncic.com/y282845/emoticons/bsflag.gif.21f42eccd34b7d1eb1608fb1b59b69c3.gif yall would pull some...oh you didnt test it right or your electric isnt up to par
  • Locked
793
  • Locked
COMPLETED Small 4channel amp
I'm really tempted to grab a 4k db 🤔
19
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
Yea I don't think I'll be throwing anything like that too it lmao. I think I'll be happy either way I decide to go but I'm just excited thinking...
JDBoogie
JDBoogie
Round Rock TX
JasonPaul
