RE MX 12'' or JL W7 12'' sub?
Which one would you buy, i will be upgrading to one of these in about a month. I'm also considering 2 RE SX's as well.
What are the Pros and cons of the RE MX?
i not sure to be honest but i can tell that i found an RE audio sub on sale its one series below the SX
its the SE12D4 model the are on sale for $99 dollars at rickies discount electronics and they are normally $169...im telling anybody about them that might want a RE subwoofer because ive never seen one that cheap before.
you could get 4 of those at that price at the same price you could get 1 MX 12" subwoofer.
here are the specs of the SE12D4
SE12D4 12" 600W RMS Dual 4 Ohm Voice Coil SE Series Subwoofer
Electrical Q Value -Qes: 0.49
Mechanical Q Value -Qms: 4.5
Total Speaker Q Value -Qts: 0.44
Free Air Resonance -Fs: 25.1 Hz
Equivalent Compliance -Vas: 72.9 liters
One-Way, Linear Excursion -Xmax: 18 mm
Efficiency -SPL 1W/1m: 86.1 dB SPL
Effective Piston Area -Sd: 480 cm^2
DC Resistance -Re: 2.8 ohm
Force Factor -Bl: 17.7
Mounting Depth - 6.5"
http://www.rickiesdiscountelectronics.com/re-audio-se12d4-12-600w-rms-dual-4-ohm-voice-coil-se-series-sub-16508.html
i had four mx 12's
if you dont have a SHIIIIIIIIIIIT TONNNNNNNNNNNNNN of power then dont bother... the thing is inefficient as all he11
but its still a real nice sub and sounds pretty good //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
get one SX 12 and be happy
I'd do the jl audio 12 w7, it would compliment ur diamonds quite well.what amp do u have for it, I recommend the arc audio ks 1000.1 ( $549 at woofersetc.com but u can find it for $399 from someone on here. That's how much I'm getting mine for. I myself was thinking of the 12 w7 but I decided on the hertz mille ml 3000 15".
endofdays89
Banned
endofdays89
missouri
nauc
