RCA plugs
thats an amp turn on lead. they put them on there so you don't have to run a seperate wire from your head unit to your amp(s) for the turn on lead. if you don't need it, don't worry about it! //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
actually no its not a turn on lead ...its a ground to help reject noise from entering via the rcas...thing is sometimes it works like an antena for noise
really? well color me stupid!! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif i kinda always assumed thats what they were (but never used them b/c of potential noise issues). learn somethin new everyday huh?
how does an alternator whine sound compared to engine noise? i think i have this problem, so if i was to ground it, would i go from chassis of car to chassis of car? or the head unit ground to the ground of the amp making the noise? thanks
Well, and engine goes vroom vroom......... //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Nothing through the speakers though.....
Alternator whine appears as a high pitched whining noise that plays through your speakers and sometimes increases or changes frequency with different engine RPM's.
A way to check for this is to set your volume control to its lowest position with the unit on and listen for this to occur. If it does not- then you are in good shape.
take it easy,
-zane
well, then i have a problem here, i do get that whining noise. my car is apart right now. i used that wire on my rca plugs and grounded one end to the amp, and the other end to the head unit ground, but the noise is still there. am i doing this right? or do i have a different problem? let me know asap please, so i can go put my car back together //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
ya know.... i get a high pitched whining noise in my truck too! but it's only on the passenger side of my truck. come to think of it, it's only when my girlfriend is riding with me. hmmmm........... what can i do to eliminate that noise? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Alternator noise in your speakers usually comes from power influence on your signal wires, where it is then amplified and sent to your speakers. Avoid routing RCA's near your power leads. If they must come in contact, only cross them at 90 degrees, minimizing the influence.
hi i got that same alternator problem...but i disconnected the "turn on leads' that came with the RCA's and the noise went...i think those wires on the RCA's are one of the main causes of noise and shoudl be the first thing to check before taking your car apart.
if the noise still doesn't go...u can try using a Ground Loop Isolator...although it might deprive your amp of some gain voltage.
No make or model number on it? Do you have an exact picture of the rear and all its glory?
808
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
817
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
698
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
813
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
922
wickedmooch
wickedmooch
South Lyon, MI
MxRacerCam
    May 31, 2024
    May 24, 2024
