RCA plugs
While it is against the normal install rules- if isolating the RCA's away from everything does not resolve this problem. Try moving the remote wire so that it sits right next to the power wire on the opposite side of the car that the RCA's are on. Sometimes even the minor voltage that flows through the remote leads is enough to provide a slight influence of noise into the RCA's.
take it easy,
-zane
no freakin way?? :p and did it have lots of freakin whine or what??? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
going to answer that one---- Nope!! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif I dont know what it is for sure, Dodge's crazy Electrical System in the Daytona/Laser vehicles is likely the culprit.
Some given rules have to be deviated from slightly in certain installation situations.
take it easy,
-zane
No make or model number on it? Do you have an exact picture of the rear and all its glory?
8
743
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
5
720
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
624
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
6
775
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
11
913
wickedmooch
wickedmooch
South Lyon, MI
MxRacerCam
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
