RCA converter
  • 3
SPLguy420
Pimp
491
michigan
Does anyone know anything about RCA converters? Not sure of thier technical name but they hook up to your 6 x 9's or speakers and will convert your speaker level outputs to line level or some ****, so you dont need any rca wires from your head unit, get it from speakers, just easier.
now my question is does this reduce subwoofer quality?
If thats all you can use there fine.
I use one myself.
ebay is prob cheap, but i went on knukonceptz site and saw that theres are cheap and are good quality.
No make or model number on it? Do you have an exact picture of the rear and all its glory?
8
772
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
5
767
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
657
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
6
793
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
11
916
SPLguy420
Pimp
SPLguy420
michigan
Rawr-DQ
winkychevelle
    May 24, 2024
