Range Rover Classic + Havoc 18 Build
Looks good but you may want to edit that video, you got your license plate in it. I just noticed you blacked it out in the first set of pictures so I figured you were trying to keep it on the DL or whatever.
noted.... thanks!
The difference in 96 to 98 db is going to net you about an 22% difference in output, all things considered equal. When it comes to 325 per channel...
826
Yeah but accubass only restores the bass roll off. It doesn't take an incomplete signal range and make it a full range signal.
13
Okay, couple of suggestions With this being a sealed enclosure. Play with the position of the enclosure. Sub firing back, sub firing forward, and...
Hpf set to 80hz door speakers really shouldn't play lower than that without specific design inputs ie: sealed doors, fully deadened doors, mounted...
williambrea
DD>AQ
williambrea
Roanoke VA
williambrea
