" big 3 ?? " amp wire size ?
  • 4
Jason Eden
Hi i have an saz 1500 and a sax 100.4 I was thinking about doing the big 3
is it ok to use 4 ga. ?
and when i run the power wire to the back of my truck for the amps should i run 0 ga. and if i do 0 ga to the junction should i run a 4 ga to each amp from there or just run 0 ga all the way ?
also you think a 1800 battery is good enough or should i get a 2400 " i am running 2 compressors for my air bag system " and im going to get a 130 amp alternator
thanks a lot for any help .
If you want to get the best i would get 0 gauge welding cable, otherwise if you looking for minimum for your setup i would get 2 gauge but make sure its copper!
You want the same size wire in your Big 3 set up as you are running from amp to disto block. I also agree with yousing the 1/0 welding cable it has a nice heavy jacket and is designed for Hi-current application. Un-like audio cable the welding cable is manufactyred according to the National Electrical Code and has to follow the requirements of them.
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
I will still find the blame..Bad tool, cheap connectors, junk wire..LOL 🤣 🤣 I didnt have enough B12 this morning is my favorite
23
Yea I don't think I'll be throwing anything like that too it lmao. I think I'll be happy either way I decide to go but I'm just excited thinking...
Jason Eden
Jason Eden
apple valley ca.
mlstrass
audiobaun
    May 19, 2024
    May 19, 2024
