Quick recommendation on 2 ch amp for my fronts
4-Channel, Full Range, Class A/B
SQ Upgrades: Op-amps, Caps, Etc.
Tiffany style Panel Mount RCA’s
RCA and Speaker Level Inputs
Variable input gain control
Variable electronic crossover
Auto-on with Speaker level inputs
Compact chassis
Variable bass boost control
Specifications
Power @ 4Ω: 4 x 65 watts
THD @ Rated Power
Power @ 2Ω: 4 x 95 watts
Power Bridged @ 4Ω: 2 x 190W RMS
Signal to Noise Ratio > 90dB
THD + Noise
Channel Separation >60dB
Frequency Response 15Hz to 30KHz ±1dB
Input Sensitivity .25v to 5v
Dimensions in mm: 160(W) x 52(H) x 282(L) Overall: 160(W) x 52(H) x 320(L)
yeah they maybe 3 ohm u think that'll make most amps drop to 2 ohm
Excuse my ignorance, but does this mean I should not bridge the amp to run my two Infiniti fronts? I think the specs on the Zapco state a value for bridged only on a 4 ohm load...
yeah man we missed ohm load except trumpet, where u get it at ebay? be great if sell let u trade it.. we assume 4 ohm on speakers unless someone tells us, one of those 60x2 would worked., 3ohm bridged load (=1.5ohm stereo) is pushing your luck, the amp will at least run hot..
I just looked it up, my fronts are Kappa 60.5cs. 3 sites online show them to be 4 ohm.
wow man u may be better off to actually pull one out and look at back see if it say 4 or 3 ohm on it, if 4 u can bridge it if 3 run in stereo u be fine and just don't use rear channels of amp and every 6 months u can swap wires on amp to other 2 channels lol 1/2 amp run 1/2 amp gets a break lol.. and later u may think about adding 2nd set of coax or something.. if they 3 ohm eventually u maybe better off going with 65 or 75x2 2 channel if u don't add speakers..
slm9s
slm9s
WA state
audiobaun
