questions about setting gain with MM
godisanatheist
when you set gain with a MM you are basically making sure the amp doesn't try to put out more power than its rated for correct? Im pushing 500rms at 4ohms. so 500x4 sqrt = 44.7. so when the ac voltage is 44.7 the amp puts out 500rms correct? ok so we do this with a 50hz testtone. isn't just being on the safe side because if you play some loud music at 3/4 volume then check the voltage it won't even go as high as 44.7. am i missing something here? most music isn't like a testtone so setting gains with one would be ultra-conservative, same goes for using an o-scope as the shape would change with different music. and what about underrated amps how do you take those into account? I still think setting gains while playing most bass heavy/loudest song on your library/playlist is better, since you kinda know nothing else is as loud as that and if you need louder bass on other songs you can always change the pre-amp level on the headunit.
V^2/R = power. I take it you are using this for highs, so probably 4 ohm speakers. so it would be the square root of power x resistance or 2000
just did the math and it comes out the same anyway...oops
In theory.
I gave up on the DMM setting and set by ear. Turn it up until you hear a little distortion then back it down. just use some common sense, if it starts sounding like shiz, turn it down
I mean.. i know its the safe side and all. but **** i wanna get the most outta my amp. i don't listen to test tones on my system. I find even the distortion thing varies upon song so I just pick a song which is really bass heavy. i go bit lower than the distortion level. i find that my gain level is still somewhat higher than if i had set it with a MM. (right now its is halfway on my jl 500/1, bass boost less than +3). its rare that a song is too loud or i feel as if its pushing my sub too hard if it is then I turn down sub output from the HU.
btw does it matter wehter you use an analog or digital multimeter. ive been using an analog one.. shouldnt matter right?
godisanatheist
godisanatheist
canada
godisanatheist
