Questions About Installing Speakers in Car
Joel114
CarAudio.com Recruit
67
I plan on buying this kit to replace my factory speakers in my 2005 pontiac sunfire (it is pretty much a chevy cavalier). It is a coupe with a woofer and tweeter on each door, and two woofers above the trunk? Would I be able to use my stock radio and wiring for them? Would I need an amp to power them? Do I need anything else besides the kit and maybe some crimps?
You'll want an amp. Technically you could use your stock head unit but they will be severely underpowered and will not sound good at all.
These are the speaker models (6.5+6x9) sort of just newer, what would you recommend for an amp?
I would avoid 3 ways as they are mostly garbage unless you get to some real high end ones. For your budget I would recommend using all the money on the front stage.You get a much better return on money spent.
Joel114
Joel114
ckeeler11
