problem w/ my amp!?
slazer
i have a 300 Watt Legacy amplifier. I hooked it up right the other day, then about 2 days later it went almost silent, i can still hear my speakers, but they are not loud at all, I can barely hear it, and i've checked all of the fuses, none are bown, do any of yall know what the problem could be?!
If you can still hear them, then it's not the fuse 'cause there would not sound at all if it was. Double and triple check all connections. Make sure that the power, ground, and remote did not get switched around somehow. If they are all ok, then try a different ground.
check the thread "no sound from woofers " in technical help, i put a list to check the amp n stuff. there might somethin wrong w ur amp. good luck
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
847
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
756
If a sub's voicecoil fails, it will usually drop impedance causing too much current to go back to the amplifier. The amplifier then protects...
15
Have you checked the fuse block. With time, tight connections can loosen and cause failure. Refresh those contact points and test again. Remember...
If you have easy access to the RCA wires at radio side, disconnect them. If no easy access, use a spare set of RCA wires to plug into the amp...
slazer
slazer
Houston
Matador
Decebal
    Jun 10, 2024
