problem w/ my amp!?
slazer
i have a 300 Watt Legacy amplifier. I hooked it up right the other day, then about 2 days later it went almost silent, i can still hear my speakers, but they are not loud at all, I can barely hear it, and i've checked all of the fuses, none are bown, do any of yall know what the problem could be?!
If you can still hear them, then it's not the fuse 'cause there would not sound at all if it was. Double and triple check all connections. Make sure that the power, ground, and remote did not get switched around somehow. If they are all ok, then try a different ground.
check the thread "no sound from woofers " in technical help, i put a list to check the amp n stuff. there might somethin wrong w ur amp. good luck
slazer
slazer
Houston
Matador
