SOLD Powermaster 12/16v charger, Shuriken BT-120s batteries
  • 2
SQcrewcab
ILLINOIS
Powermaster charger, charges 12 and 16v batts, 1yr old, on/off switch is stuck in the ON posistion. Just a rocker style switch, could be changed out. $170 shipped
2 Shuriken batteries BT-120s. Both are 14 months old, i am original owner, always taken care of and charged with the PM charger. Both have the decals faded from being on the porch for a few days, the Sun took the color right out of the decals. Both batts will sit at 13 v for a few weeks and stay at 12.8-12.9 for a few months(thats the longest they went with out seeing a charge) . I will get the pics up tonight or first thing in morning. Batts are $170 shipped each.
I have a jeep grand cherokee that is controlled by pcm but I have a external voltage regulator . I just switched to cmax and when I went to turn...
I have this one as well and it has been very useful. Would recommend if you need a versatile battery charger/small power supply.
Did you consider using the PAC AmpPRO 4, AP4-CH31? It will connect between factory amp and head unit and allow you to have RCA outputs for the amps.
Do you have about $100 to waste? Try a cheap amp that has line-level inputs, see if that helps. WalMart carries a 4 Channel Jensen amp, for its...
SQcrewcab
SQcrewcab
ILLINOIS
uz1290
    May 24, 2024
    May 23, 2024
