Power wire touches ground a few times
I have a kenwood kac m3004 and when I was trying to adjust some wires my power and ground kept rouching because of a stray wire now only one rca plays. I took it part and found a blown 22uf capcitor also
Awesome. This is why you should always disconnect your battery before working with electrical components, especially expensive car related components.
Edit: Why do you have stray wires? Maybe I'm OCD but my wires are clean as hell and heatshrunk to avoid anything like this from happening.
well, you are doing the right thing by getting help.
you don't want this to happen again right? go recheck every single point of connection/termination of your wiring. fix it now, so you dont have a fire later - that's my advice
you'll have to buy a new amp, no one will repair them if they're less than $100. not worth it imo
and in reference to fiverman below me, generally its not that easy. OP can fix one cap if he wants but i doubt itll fix his issue. it's a $100 amp and one capacitor isnt usually the only problem
for the hell of it OP, post pics of the amp guts
I just wanted to know could that be the culprit? How would I go I about testing the ics of the circuit?
Yes, that's obviously what broke your amp. If you can repair it, go for it, but I'd say the amp is not a paper weight. Judging by you questioning if that's what popped your amp, I don't think you can repair it.
A fuse or breaker used?
That wouldn't have blown/tripped fast enough to protect anything in this situation
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
So u know the individual slots on the ISO connectors and where they go? 12 volt red is accessories. etc. Red wire goes to the amplifier...
Oh, total opposite. i play with storage bins full of wire scraps from past installs for fun. I hoard decent grade wires from audio homies...
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
tramont
tramont
jonesboro,ga
jordon
    May 24, 2024
