port help
  • 1
bass_mekanik
i got 0.5 2 go til 145dbs
I am in the proces of builting a polrted box for a mates rockford HE 12" it is 2 cuft i was just wondering how close to the box wall i can have the 4" wide port it has to be 10.25 inches long from memory if the box is only 12" deep will the port be too close to the back wall? too close or fine?
how would the sub sound if the port was to be facing up and the sub facing back would that be ok as long as the port fired up thru the empty speaker hole in the rear shel or what other port setup could i use what lenght woulf 2 4" ports need to be to substitute the 10.25 inch long one as i already have one 4" port. So if i got another one the same what lenght would i need it to get the same tuning frequency??
I'd have the internal port end 7" away from the back wall and just roundover that corner. That back (rounded) wall should effectively extend the...
None so far, there was a factory 8 inch subwoofer that I took out for a pass through, I'm definitely going to have to get some sound deadening...
10
Yes. I do not fully understand the question, but if the manufacturer suggests such a big port, it is probably because it has a high QTS. If it...
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
771
bass_mekanik
bass_mekanik
Launceston Tasmania
bass_mekanik
    May 24, 2024
    May 23, 2024
