Port box size for 2 alpine type r 12's
Going from memory on my last build 2cuft each port 12x1.5x22
Idd build 2 boxes to look like 1 with 2 port
Aim for 5cuft to allow for port/ sub
Then come back once you have a box size and someone will calculate the correct port size for the cuft you have and the hz you require
First draw up the biggest box you wish,
And work out the internal volume with atleat 3/4" mdf and divide that by 2
With is for 2 subs
Then minus the sub displacement and rough port displacement an you'll have the box cuft approximately.
Off then you'll be able to calculate the correct port and hz and final cuft
Then if you need you add os subtract volume from the box
This is not the best way but does work
So I don't want to spend 400$ to get a custom built ported box, so I've decided to make my own. Does anyone know the specifications I need to build it to? The port sizes, where to put the ports, what to tune it to, etc?
I really hope that's an exaggeration. You can get solid, sturdy, quality-work boxes for about $100 on this forum.
A box for two Type R's for $100? That will take at least a sheet of mdf which is around $31 last i checked then you have glue, carpet, etc.
I hope someones time and skills is worth more than that.
I'm new to this forum and every customs audio shop I have gone to has told me that I'm looking at 616$ from audio express, 450$ from 702 motoring, and around 500$ from a place called SS audio. Unless anyone on this forum lives in Las Vegas... I'm rather screwed lol. If anyone does happen to live in Las Vegas, I'd be willing to pay 300$ for a box and help with installation.
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
699
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
871
Karl09
Karl09
Las vegas
dirtyunclerandy
    May 18, 2024
    May 16, 2024
