Polypropylene sub cones
LoudCrownVic
1/1 of Team Team Team
What works best as an adhesive for it?
Sub is an Infinity 1240w
I have 30 min crystal clear epoxy and it says will not bond polypropylene. Superglue does not seem to work so hot either, I tested it and it seems to melt the plastic. I have Testors Model glue for like plastic models, that may work?
Well... It's for a cracked cone. I figured that epoxy would work.
Well, I'm gonna dip into my other glues and see what I come up with.
Goddarn it why can't they just use fakking paper.
BTW I did not really understand either of the last two posts.
what dont you understand about this statement;
"call re and ask if you can buy some of their black glue to fix your sub"
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Works I guess. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
If I can't find an alternative.
Found some Loctite Superglue for "all plastics" that should work...
THen I guess I will fill the bigger holes with hot glue?
hell, I was supposed to get 10 bucks to fix this sub, and Ive already spent more than that trying to get an effective adhesive.
Ok I used the loctite. It adhered fast, but it was sloppy. I will def pick up some professional CA glue in the future, while this stuff worked well enough (in conjunction with hot glue) it made a mess and was difficult to apply smoothly.
The sub is repaired. Thanks for the moral support.
LoudCrownVic
LoudCrownVic
Scales Bump, IL
LoudCrownVic
