please help!! keep frying subs!
I'd take a picture of how you have the sub wired, and also a picture of you amp where the settings are... Let us see exactly how you have it all atm...
[/img]
second get that wire out of a bind and re do that connection. take it out all the way get it sright as you can into hte terminal and re-tighten it. tighten it good then shake the wire around and see if its loose if it is loosen it and tighten it again better. once it doesn't move after to move it around go and 1/8 or 1/4 turn..
---------- Post added at 10:22 AM ---------- Previous post was at 10:22 AM ----------
the one that says frequency set it to 60 or 70..
981
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
930
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
levisrygley
nashville
ANTHONY.S1982
    May 12, 2024
Brendon Jenness
    May 11, 2024
