playing with sketchup...would this work?
TrlcKed_OuT
las Vegas
hey guys so im just fooling around trying to learn sketchup so i drew this..for no particular driver and the dimensions are just kinda random as well but just the overall idea..would it work? to me its just a reversed 4th order bandpass?? tell me your thoughts...
http://img822.imageshack.us/img822/6446/box12.png' alt='box12.png'> Uploaded with ImageShack.us[/img]
Im not a box expert by any means.. but wouldnt the inner board actually holding the subs have to be longer than the boards on the outside? th 3' ones?
Also.. like i said im not a board expert, but i had a much smaller version of this with just 1 sub on each side, sounded decent.. so id presume itd work
ya the inner boards might be a hair longer but the 3' is an outside dimension so theres 1.5'' short there but im not sure just kinda threw it together not real dimensons for anything...kinda thinking something like this for my 4 sa-8's with the middle sections being plexi....
To do this magic, should the microphone always be kept in the driver's seat or on the dashboard?...since that is where it must go in phase with...
I had this same issue with my Sony. When I first got it I had speakers hooked up to the head unit without amplifiers and it worked fine. Once I...
Hello, I already posted in general but wanted to also post in here. I recently installed a set of used JL audio shallow depth 12W 1v3-4 inside an...
Makes sense. You may be right on the gain; 2 subs on 300 watts seems anemic.
46
4K
I'd try wiring the subs to 4 ohm (series parallel) and see if that makes the problem go away.
TrlcKed_OuT
TrlcKed_OuT
las Vegas
helotaxi
    May 18, 2024
    May 16, 2024
