Planet Audio
  • Thread starter <JBoges8>
  • Start date
  • Replies 4
  • Views 13K
  • 2
The only one I have dealt with is the 2500d. Put it in a Ford Explorer Pushing two 15"L7's. That was about 4months ago. Haven't seen the guy since. But I here him going up and down the road all the time
Good luck! I posted a similar question back on Dec. 21 and have yet to get a response re: th planet audio part of th qstn. Best I can tell u is go to www.usacoustics.com and click on reviews-there's a comparison from a magazine of a us acoustics model vs th planet audio P706 and some other brand. If u ferret thru th data, th planet audio one actually looks the best in my book-mo power@14.4 volts(it has an un-regulated supply, which I prefer), and, most importantly, a higher rating in th almighty "sound quality" category. Back to the supply, it's actually what they call a "quasi-regulated" supply; th pre-amp stage is regulated Class A, and th output stage is un-regulated. Idea is to get the sound quality/accuracy advantage of class A in th low-current requirement pre-amp stage, without th inefficiency, xtra heat&wasted space that would happen if th output stage were class A too(mosfet power supplies have enabled a narrowing of th gap between class A and class AB sound quality if that's any consolation). Since us acoustic amps are supposed to be one of the better quality low budget amps-that's what I've read-Jensens are another one-I guess that review must mean that planet audio-at least th mosfet P706-is also in that category. Sounds good in theory, for whatever that's worth!
Oh, and one more thing-they're made at th same plant as Boss Audio, which doesn't help matters(they're kinda crappy), but they(planet audio) are more expensive and spec out better, so maybe it's not that incriminating. Lemme know how it works out if u do go with a planet audio amp, I'll pass th info along...
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
Thanks man I’ll give it a try I’m usually pretty bad at this kind of stuff. I wasn’t sure if there was a website or something that had a picture I...
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
186
Guest
dcsoundguy
    May 31, 2024
    May 24, 2024
