PhatTonyDeMarco's Personal Build :D
Jasper jig = $40
Scrap MDF = free //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
true but getting any size hole you want in 1/16" increments up to 18" is worth the $40 //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
~Magick_Man~
even if I slipped a Home depot a $100 bill they still wouldn't be able to give me perfect cuts.... their saw is all jacked up. It'll start out accurate, but not at the end. Lame Shit. It doesn't cut a perfect vertical cut. /
I just layed a layer of glass down, feelin kinda buzzed //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
I got the holes cut and all, I used the scrap wood idea and it worked perfectly, thanks Mountain Man //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I should be done today, as long as the resin dries fairly quickly and I can put the top on.
cant make a homemade jasper jig... u use the homemade compas to draw a circle then use a jigsaw to cut it out //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Well, she's all done //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I will get pics up in a little bit.
I cant wait to get this in, I just got a Jeep 2dr Cherokee and I am hoping it gets insanely loud...
so instead of just making your box by yourself in the first place in less than a day you had to go through the whole jordantyler deal. did you not have enough confidence in yourself to do it right or what?
Yup, my previous boxes were less than average, and never assembled properly (e.g. port walls always crooked, gaps, just no good)... So I decided to get a set of corner clamps and take my time, I pre drilled every hole (never done that before) and did everything correctly.
Needless to say, I am proud of what I have done.
Hey, good work tony... you'll get better the more you do it... but don't be surprised if yours falls apart too lol... that sub is ridiculous... mine was double baffled and screwed n glued to no end... good luck
PhatTonyDeMarco
C0CK,its whats for dinner
PhatTonyDeMarco
West Palm Beach, FL
iceteebone
