I don't want to add more power. That would take way more cash then I want to spend. I'm trying to get the most out of what I already have. I really wanted to recone to 18s and do a wall but I don't want to up the front stage anymore to keep up with a wall. It has to blend, I can gain a few dbs right now and the fronts will be fine.i did mayhems on 2 ab 500.1 amps strapped at .7 daily ,no problem
I'm not saying they have to have more power but I would eventually want itWhat about level 5s?
I'd go with level 5s on a 5 k that's my dream set up personally, you could beat the hell out of them all day long and never worry about anything but then again if you wanted to add power you always couldI don't want to add more power. That would take way more cash then I want to spend. I'm trying to get the most out of what I already have. I really wanted to recone to 18s and do a wall but I don't want to up the front stage anymore to keep up with a wall. It has to blend, I can gain a few dbs right now and the fronts will be fine.
---------- Post added at 09:22 PM ---------- Previous post was at 09:21 PM ----------
Heat up too fast because of that stock alt //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gifZcon's get my vote. Xcon's are great for anything under 2k but anything over that and you'll notice they heat up too fast. SSA subs are extremely efficient too.
I can't get a 50 now. Tuned at 38 gets me a 149.5 in the kick. 47 at the dashthe mayhems will do fine on 5k,should still be doing a solid 150 too
I have plenty of battery reserve to hold my voltage, the sub just doesn't like that much power. Most 3" 4 layers don't like over 2k unless they are specifically designed for it (like the 9500's for example...)Heat up too fast because of that stock alt //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
I got a 7.5 inch octo now. I don't have room for more port. I could tune higher, it's changeable just haven't made the 43hz port yetuse aeros ,tune the box higher with 4 6" ports and plug off 2 for daily
Clamped 4800 with rise on 60hz5k amp or 5k clamped power huge diff...
50 in the kick will be easy not on the dash. To highest I can go is 43 right now.try to get a port tuned to your cars max frequency peak.then a 50 will be easy
highest freq ?50 in the kick will be easy not on the dash. To highest I can go is 43 right now.
