Orion 2500D questions
SWEET06CAMRY
Hey guys.
I just got a Orion 2500D and i'm confused //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Is this a two channel ??? //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
I had a Power acoustik A2400DB and the channel looked different //content.invisioncic.com/y282845/emoticons/blush.gif.99bc659ee2012b7d826165e26fb5eebe.gif
How come it has 2 ground inputs and 2 power inputs ???
Should I just bridge it ?
Thanks guys...
I really need all the input about this amp I can possibly get... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Internally bridged
I'm sorry dude I'm not really following you //content.invisioncic.com/y282845/emoticons/blush.gif.99bc659ee2012b7d826165e26fb5eebe.gif//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Can you explain it to me ???//content.invisioncic.com/y282845/emoticons/blush.gif.99bc659ee2012b7d826165e26fb5eebe.gif
they just make it easier to wire up multiple subs to it, it only has a 1 ch on the inside but it splits the pos and neg so you can wire up 2 subs easy
just pick a side and use it
it needs lots of power, so use both power inputs
this is stuff you shoulda learnded before you bought it...//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I know I should have learned about it before buying it but now i got it and it looks completaly different than a good ole monoblock amp //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Can I use both power inputs with just one wire coming from the battery ?
or do I need to run 2 power wires ?//content.invisioncic.com/y282845/emoticons/blush.gif.99bc659ee2012b7d826165e26fb5eebe.gif
u don't bridge a mono amp. It doesn't matter whether you use all four speaker leads, or just the two. Inside the amp, they are both connected. It just makes it easier for your wiring, so you don't have to smudge so much wire into one lead.
Just like what they said above!
SWEET06CAMRY
SWEET06CAMRY
SANTA ANA CALIFORNIA
SWEET06CAMRY
