orion 1200d
  • 4
traksta15
I love lamp.
If I want to push 1 sub with my orion 1200d, which wire terminals do I use? The give you 4 and I only have 2, (single voice coil sub). I haven't used it in a few months and im a little confused now, thanks in advance guys! Sorry for the dumb question.
Lol, so I can use either the left or the right channel?
I was hoping I had it wired wrong, im having trouble getting my 1508 to sound good. I tried the left, and tried using the left + and the right - but nothing worked.
there is no left or right it is internally 'bridged' to form a single channel, its just easier to work with two sets of inputs than one, just use one of the +'s and one of the -'s... i've had six 1200d's and around 8 2500d's lol, i think i've figured out how to plug them sambishez in //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
it has almost ZERO output. You can barely tell it's even there. Box is 1 cube @ 34 hz, downfiring under my back seat. I've checked my settings over and over again, had it in a 1 cube @ 40hz box and had the same problems. It's gotta be either the sub or the amp....those are the only two constants in both installs. How do I bridge my 225 hcca? I'll hook that up just to try it, anyone know the output of that amp at 4 ohms?
so I hooked it up to my 225hcca and it sounds better than the orion 1200d. It's still not where it should be.
so im thinking about either doing 2 10s under my seat at around 600 each or doing a blow through. This is making me so mad!!! just had to rant guys....
im so mad, I don't know what to do about it.
Ditch the dd and move on to something bigger and better?
Forget doing a small system and do a full on blow through?
Build an under seat sealed box for my sundown e8 and use my 225hcca?
well it sounds better than my 1200d at 4 ohms.
Think one of my channels is busted? Think maybe that might be the problem. It sounds hollow and has almost no output
Ive seen so many amps done this way over the years. Especially ones that had the Molex plugs and a couple others
949
I have created a post with all related information regarding the build under this link: https://www.caraudio.com/threads/2000-camry-build.614208/
50
4K
Yes, they do. As for the Taramps remote control, it is for use with the EQ they sell, not as a remote bass knob. They are not very sophisticated...
24
4K
traksta15
I love lamp.
traksta15
Mcalester, Ok
traksta15
    May 24, 2024
