orion 1200d
Lol, so I can use either the left or the right channel?
I was hoping I had it wired wrong, im having trouble getting my 1508 to sound good. I tried the left, and tried using the left + and the right - but nothing worked.
there is no left or right it is internally 'bridged' to form a single channel, its just easier to work with two sets of inputs than one, just use one of the +'s and one of the -'s... i've had six 1200d's and around 8 2500d's lol, i think i've figured out how to plug them sambishez in //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
it has almost ZERO output. You can barely tell it's even there. Box is 1 cube @ 34 hz, downfiring under my back seat. I've checked my settings over and over again, had it in a 1 cube @ 40hz box and had the same problems. It's gotta be either the sub or the amp....those are the only two constants in both installs. How do I bridge my 225 hcca? I'll hook that up just to try it, anyone know the output of that amp at 4 ohms?
so I hooked it up to my 225hcca and it sounds better than the orion 1200d. It's still not where it should be.
so im thinking about either doing 2 10s under my seat at around 600 each or doing a blow through. This is making me so mad!!! just had to rant guys....
im so mad, I don't know what to do about it.
Ditch the dd and move on to something bigger and better?
Forget doing a small system and do a full on blow through?
Build an under seat sealed box for my sundown e8 and use my 225hcca?
traksta15
I love lamp.
traksta15
Mcalester, Ok
traksta15
