thirdgen
Ok, so Im SURE this has been asked before, but I guess I worded the search wrong. Hmmmmm, pros and cons, I guess.
One sub with 5kw:
Pros:
Cheaper
Space saver
Cons:
More strain on woofer due to higher wattage (probably wouldn't last as long)
Not as loud?
Two subs with 2.5kw a piece:
Pros:
Louder?
Last longer due to lower wattage per sub being used.
Cons:
Requires more space to install
Would be more expensive, cause buying a second woofer, and more wood for box.
What are some opinions about this? I want to be able to ripple the windshield a little. But if I go with a two woofer setup, I will have to remove my rear seats, and lose any "stealth" to the install. I will do this if deemed worth it, or necessary. Any input is appreciated. Thanks
One sub with 5kw:
Pros:
Cheaper
Space saver
Cons:
Not as loud?
Pros:
Louder?
Cons:
