Old School to now
the budget lanzars are capable of a clean output SIGNAL why waste your money?
You CANNOT HEAR THE DIFFERENCE. Nobody has taken Mr. Clark's money and you're not about to do so either.
Reliability, resale value, efficiency, crossover options, brand loyalty, aesthetics.
Plenty of legit reasons.
Bullshit. Nearly all the amps use very similar parts. Only the high-end gear use hi end parts like silver conductor plate capacitors and higher output transistors..
I can hear the difference every time I've ever switched amps.
Different circuits even have a unique sound.
Look at PASMAG | PERFORMANCE AUTO AND SOUND - Welcome look through the test.. if you wanna put some money down send me an amp you think is gonna sound excellent.. I'll get a oscope and play various passages through them starting with some sinewaves to some electric music and we will see how the wave forms are different between your amp and my pg xenon with a reactive load. I'll compare the input signal to each amps actual output signal in line with the load and then the speakers actual output signal. From 1 watt up to there 1℅thd limit..
Bullshit. Nearly all the amps use very similar parts. Only the high-end gear use hi end parts like silver conductor plate capacitors and higher output transistors..I can hear the difference every time I've ever switched amps.
Cool bud. Do win the $10,000. You will be the first. I'm looking forward to playing the distortion tracks for you. I'm going to record the whole thing so you can't deny it. .03% all the way to 10%. Same song clip. Back to back at the same volume.
For the sake of argument, what's different about a "reactive load" that's going to change the output waveform of an amp without "high quality" parts?
If you think you can hear the difference between using silver capacitors I've got some unicorn horn dust to sell you. You're the kind of sucker who buys 100$ a foot RCA cables or 8$ a foot 12 gauge speaker wire thinking that you can hear the difference.
Pear Cable Audio Cables - Car Audio, Home Audio, and Home Theater Products (yes there really is one born every minute)
Seriously, give it up. NOBODY has taken Richard Clark's money. More literate folks than you with "magical ears" have tried.
I will never say a good amp and a ****** amp is the same. The good amp will produce more power which is audible. More headroom for dynamics is a real thing. But it all comes down to power.
Big a good amp down to the ****** amps power level and they will be the same.
Just to add. Bama is struggling.
I will never say a good amp and a ****** amp is the same. The good amp will produce more power which is audible. More headroom for dynamics is a real thing. But it all comes down to power. Big a good amp down to the ****** amps power level and they will be the same.
It's more to it than that.. dynamics, channel separation, power supply and output separation/isolattion. Dampening I think you get the point..
You absolutely can. I'd suggest you do some real reading.
Start at mundorfs site..
http://www.mundorf.com/english%201.1/kondensatoren.htm
Maybe talk to some techs at zapco and Tru..
Are you measuring the actual the? Do you know what the is?
Lol. They start of slow sometimes. They'll come out in the second half swinging.
You absolutely can. I'd suggest you do some real reading. Start at mundorfs site..
I bet you also believe everything Trump says.
---------- Post added at 08:40 PM ---------- Previous post was at 08:39 PM ----------
The way it looks now. Auburn is taking the SEC. Coming out of nowhere. If we would have played Clemson right we'd be in the top 5
llebcire
llebcire
Iowa
llebcire
