Odd Sub Problem....
Zacmc212
6
FL
I just reinstalled my subs/amp, and it hitting when there is no music playing.
For example in betwen switching cds, it will thump a few times. It isnt very loud and it isnt a constant thump. But im not sure what could be causing it. I tryed to search but couldnt really think of what to type.
Could be because of clipping possably?Do you have a clean ground...
Is everything else connected properly, no wires touching exposed ends, etc...
I wouldnt say clipping would be the problem, if there is no music playing then the amplifier shouldnt be putting out any signal at all, let alone a clipped signal.
Check your grounds, if you can, I would pick another grounding spot just to be sure. Could be a shorted RCA, as mentioned. We really need some more information to be sure.
Well the rca isnt grounded, so i will try that tomarrow. I remember seeing apost where someone explained how to do thism but i cannot find it. Also im not even sure my headunit is grounded unless the wiring kit had a ground on it.
It could be the ground on the amp, because I have only used this ground when i used my nine.1 at 8ohms, so maybe this ground isnt cutting it for 2 ohms?
I dont think it would be clipping although i didnt use anything to set the gains. The Headunit is a pioneer 6600, and the amp is a nine.1, it is hooked upto a 16ov2 at 2 ohms. The agins are about 45%..
Thanks for all the suggestions
Well just to make sure it isnt the gains i am going to get a volt meter tomarrow and set them the right way according to the jl tutorial. I just dled and burned a 50hz tone.
Now i turn everything at 0 on my headunit, and al eqs off? and just play the tone with the + and - outputs touching the meter. And since it isnt a jl audio amp how do i know what to set the gains at? Should i just go with what it is for the 1000/1?
Thanks again.
Thanks again.
The voltage you'll be looking for will be the subs impedence multiplied by how many watts the amp puts out, then find the square root. For example:
The amp puts out 400 watts at 4 ohms, and you have a 2 ohm DVC sub wired to 4 ohms.
4 x 400 = 1600
square root of 1600 is 40, so look for that.
WTF are you guys talking about?
ZacMC: When you eject a CD, your amp is turning off. When you put the CD back in, it's kicking back on.
That's turn-on thump.
Well that could be it i guess, but it also does it inbetween songs.
I was messing with it today, and it still does it when the vol. is turned all the way down, and if i play a song and turn the vol. down is doesnt do it.
So does that mean is isnt sending any other "clipped signals" since it doesnt do it while im playing a song.
Also i havnt tried any of the siggestions yet because i have been swamped with homework, but hopefully i can today when i get back from class.
Zacmc212
Zacmc212
FL
PhatTonyDeMarco
