newbie here - hope u can help
tuckj
Just finished replacing a defective “Panasonic” cd player with a new Alpine. Everything works great except when the deck is turned on. There is a fairly loud thump coming from the sub. It wasn’t there with the old deck
D461 MTX amp
12” ExPlod
Alpine deck CDE-9845.
Simple system – but this sound scares me……..thanks a million.
This is the full technical guide to repair the problem-
Replace the words processor and equalizer with head unit as this is the cause of the thump.
2.2 My system "pops" when I turn it off. What is happening and how
can I get rid of it? [JD]
This kind of problem is often caused by transients in the signal
processor as it powers down finding their way into the signal path,
which the amplifier then transmits to the speakers.
Usually this can be solved by adding a little turn-off delay to the
processor. This allows the processor to stay powered on for a short
time after the amplifiers have powered down, thus preventing the pop.
Many components sold today (such as crossovers, equalizers, etc) have
delays built-in. Read your manual to see if it is possible to set this
delay on your piece of equipment or be sure to look for this feature
during your next car audio purchase.
If your processor does not have this feature, you can build your own
delay circuit with a diode and a capacitor. Add a 1N4004 diode in
series with the processor's turn-on lead, striped side towards the EQ.
Then add a capacitor in parallel, the (+) side of the cap connects to
the striped (processor) side of the diode, the (-) side of the cap goes
to ground (not the radio or EQ chassis - connect to the car chassis).
Experimenting with the cap value will give you the right amount of delay
before the EQ shuts off. You don't want it too long, just long enough to
make sure the amp is off before the EQ powers down. 220 - 1000 uF is
about right, and make sure the cap is a polarized electrolytic, 16V or
higher. Also keep in mind that the diode will introduce a 0.7V drop on
the remote wire, which can cause the processor to power down before the
rest of the system.
Edit- in the event of a turn on pop/thump the amplifier turns on before the head units rca's turn on. When the the head units RCA's energize the amp will pop/thump the speakers this is why most amps have a soft turn on curcuit that delays powerup to allow the headunits to turn on first, If your amplifier is turning on before the RCA's on the head units turn on then you need to delay the remote turn on leads signal.
check the grounds/connections???
wow! what great advice............ He said he's new. what should he check for? that they're still there?
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
I thought the thump problem was more common with component amps? I too just added a sub/amp (check the sig) combo and have had ZERO problems. Recheck everything, grounds (head unit and amp), RCA’s, remote turn no wire. Good luck!
Thanks all !!!!!
Been away from computer for awhile.......lots of good advice to try.........I know the grounds are AOK, and will key on "head unit delay"
Thanks
Great forum //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
tuckj
tuckj
Canada
tuckj
BP1Fanatic
BP1Fanatic
