Newbie gettin confused bout wiring
loudjeep
Ok sorry guys, im still very confused on wiring my subs to my amp, so im startin this post to try and get some things straight. ok first of all, i went to cardomain.com and did the wooferwizard wiring thing, which confused me. if i have 2 4ohm dual voice coil subs....how does the wiring work if i wana connect it to a 2 ch. amp., and the thing said "bridged" and i have no clue what that is. ok 2nd question, im having trouble reading that wooferwizard diagram, cause i thought that 2 channel amps have 2 sets of + and - slots, since my subs are in a sealed box that has 2 connections, meanning 2 positives nad 2 negatives..how does that all fit into a Mono block amp..which im assuming means 1 channel? please help
First, bridged is when u have 2 channels on a amp, but it can (usually) bridge it internally so u only use 1 + and 1 - from the amp. In other words it connects the 2 channels so it becomes 1, or it becomes a mono block amp. Hence the name bridging. You would have to refer to the amplifiers manual to find how which ones to use. Some amplifiers have a switch u can switch to get to bridge mode, other amps u just use the + from 1 channel and the - from the other channel.
And yes, mono blocks mean 1 channel, some mono block amps come with 2 + and 2 - connections, but they automatically bridge internally. Other's come with just 1 + and 1 -.
You would wire it according to what final load u want the amp to see
OR
loudjeep
loudjeep
Houston TX
phyphoestilic
michigan born
    May 14, 2026
michigan born
    May 14, 2026
