Newb needs a little help
get the kicker idea out of your head, i was the same way when i joined.
you can get louder and sound better for less than a 15L7 (which also uses a good amount of space)
maybe an AudioQue HDC 15 in about 4cuft ported with something like the AQ1200d or a hifonics 1600?
looking at ~$600 total if you build and install yourself
will hit hard and still sound good
lol alright cool you guys are awesome by the way thanks. It would really help if you school me on all the mono, dual channel **** what kinda amp is needed with how many watts and rms and what would be the best brands to look at for what i want
and the best sites to use to buy
there are so many options with the amount of money he is willing to spend
Im just going to rattle off sub suggestions
DD 3500 series
AQ HDC
FI BL
FI BTL
FI Q
SD Nightshade (and u get a cool name)
RE SX
RE MX
look them up on youtube or look for reviews
just use the search button for all your wattage/amp questions.
and if you buy online. while saving money is always good try and buy from authorized dealers. when **** doesnt work for some reason after you buy it you need some kind of warranty or you are **** outta luck
Mono amps are usually the best for your sub. and only look at rms ratings when looking at amps, not peak. they are all that matter
1) Mono channel amp, aka class D, just trust me
2) for a daily setup and not going too crazy, i would gear toward the 1200-2200 range
3) Brands: in order of my wants in terms of subs in the suggested range
Digital Designs http://www.ddaudio.com/dd/default.asp
Sundown Audio http://www.sundownaudio.com/
Fi Car Audio https://ssl.perfora.net/www.ficaraudio.com/sess/utn1549ebf0d3d8d89/shopdata/index.shopscript
AudioQue http://www.audioque.com/aq/index.htm
RE Audio http://reaudio.com/
They should work. I have 6.5s in my lower door to replace the 8" subs that came with my mustang. They are fantastic, and outperform the 6 x 8s...
I would add an ANL Fuse @the amplifier supply with its recommended 100 ANL fuse, and Keep the 120-150 @the Battery...
You may or may not like the sound of just dropping into the stock locations but loading into the glass is definitely going to cause some issues...
15
I guess I asked for that when I declared myself a noob. I mean the interior side of the firewall which is heat shielded with Lizard Skin.
19
I hope it ended up helping someone in here. I was right there on the Morels, but didn't need em, so I dropped out earlier than I would have, I...
14
MikeRJ13
MikeRJ13
FL
csu87
