new type Rs!! screeching noise!
i cant seem to find one
i looked on the box, the amp, the book, all i could find what i said before.
coustic amp1200db
heres the specs.
power output: 300watts RMS per channel at 4 ohms
singal to noise ratio:75 dBA
additional power output: 600 rms per channel at 2 ohms
frequency respose: 20 hz to 200hz
max input signal: 5v
max sensitivity: 100mV
i cant seem to find onei looked on the box, the amp, the book, all i could find what i said before.
coustic amp1200db
heres the specs.
See, it is not a monoblock, its a 2 channel amp.
You wired the subs wrong. The subs can be wired like you have (one sub per channel, subs not wired together), but you have them wired at 8 ohms a piece, so they are seeing something around 100 watts each. You need to wire them into 2 ohm loads each.
see if that helps anything.
coustic says it is a monoblock. 600x1 @ 2 ohms. but then they say it isn't bridgeable:confused: i'd say wire them to a single 2 ohms and try it.
Product MPN
MPN 1200db
Key Features
Amplifier Type Mono Channel
Bridgable Not Bridgable
RMS Power at 4 Ohms 300 W x 1
RMS Power at 2 Ohms 600 W x 1
Performance
Frequency Response 20 Hz - 200 Hz
Signal to Noise Ratio 75 dB
THD at Rated RMS Power 1 %
Crossover / Equalizer
Bass Boost With Bass Boost
Bass Boost Frequency 40 Hz
Low - Pass Frequency 40 Hz - 200 Hz
Other Features
Input Voltage 11 volt
3 Way Ready No
Warranty
Warranty 1 Year
Miscellaneous
Product ID 22495975
Product MPN
MPN 1200db
Key Features
Performance
Other Features
3 Way Ready No
Warranty
Warranty 1 Year
Miscellaneous
Product ID 22495975
interesting, different than what his box says.
well either way, OP, just so you know, type R's like about 600-800RMS, EACH, so that amp is gonna **** for em either way
their own website doesn't even have that model anywhere. that is relying on a couple of sites that are selling the "coustic 1200db" amplifier. assuming that is the actual model.
is this correct?
what amp do you recomend?
xbatxattackx
xbatxattackx
california
xbatxattackx
